Old 12-23-2016, 11:33 AM
Chassisguy's Avatar
Hole issue in Plate section
I did the last update and ever since when I create hole in a plate, it (software) will double it for some reason.
When I go to the shaded view the hole is not present. When I export it out as a DXF and load it into sheetcam it recognizes "double or over lapping lines"
I can go back to the plate design. Delete the hole and sure enough the is more that one. After I re-insert the hole(s) in question it is ok.
I have verified that this is occurring on more than just one design.
Anyone else have an issue with it?
I say a software thing.....but truth be known, it could very well be me :0
Old 12-23-2016, 11:50 AM
Do the help inside BT that way they will have the file and can see bezaktly what is going on.
Old 12-23-2016, 02:47 PM
Chassisguy's Avatar
I did that too.
Was just wondering if anyone else has experienced the same thing or not
Old 12-23-2016, 04:19 PM
I did that too.
Kant help you much because I find I hardly use SM.
HTML code is On
