Old 05-26-2016, 10:07 PM
Scrambled's Avatar
Need help[ with Bend-Tech pro
I just ruined 2 pieces of pipe by not paying attention. OOPS.
I was trying to make 2 bends at both ends of a piece of pipe. The first bend was fine, the second bend, the remaining length of pipe was too short, and the pipe would have come off the following die block.
Is there a way for Bend Tech to tell me I need to add more length?
I normally catch these problems, but not tonight.
Old 05-26-2016, 11:26 PM
Yes, you set the values for your machines limitations in the tool/die library.
Old 05-27-2016, 12:21 AM
Scrambled's Avatar
Looks like I need the SE version. I only have the pro.
Is it possible to upgrade from Pro to SE?
Old 05-27-2016, 09:50 AM
Yep
Old 05-27-2016, 12:23 PM
Bray D's Avatar
Bray D Bray D is offline
I have SE and it's awesome. Not only can you input the required length after a bend to ensure it doesn't pull through the follower, you can input the required length on the front side of the bend to ensure you don't have interference with your clamp/angle finder pointer, etc between bends. They even allow for different values depending on if you're making in-plane bends or out of plane bends. I can make two bends much closer together if I'm making them out of plane.
After you input those values, it'll flag it with a manufacturing warning if there's anything that exceeds your machine limitations. If the solution is to simply add some extra length, it'll automatically add the required length to your part (if you tell it to) without changing the assembly that the part came from. That length is noted so you can cut it off after you make the part.
HTML code is On
