Old 08-05-2015, 11:28 AM
Exclamation Roll Cage Templates Available Now!!!!!
New Product Release>>>>>
Roll Cage Templates:
Whether you are designing roll cages for your side by side UTV & ATV, Jeep, stock car, rock crawlers, etc, our pre-designed cages available in the Roll Cage Templates Module (RCT) will give you the ability to create a roll cage that will be a perfect fit for your vehicle. With the help of the RCT module, you can simply pick a roll cage design, then fill in your specific values to create a custom cage on the fly.
After you've finished dimensioning your cage, it can be brought into the Bend-Tech Assembly interface where you can add, delete, or edit specific parts for enhancing structural support or adding your personal touch. This allows you to customize your design even further.
Every cage designed in RCT will provide bending instructions such as cut length, bend location, bend angle, rotation, etc, these accurate numbers which can be calibrated to any of your tube benders (from manual hand bender to CNC) will be your ultimate tool for successful tube fabrication.
Another handy feature included is the auto defined tube cutting information for coping the ends of the tubes. Every part has the cutting instructions already complete with cutting wrappers available to print out.
Old 08-05-2015, 12:41 PM
The cool-ness never stops with you guys!
So cool!
Cant wait to upgrade!......and buy a bender!
Old 08-05-2015, 05:07 PM
Ordered, thank you Bend-Tech.
Old 08-06-2015, 08:11 AM
Bstomper's Avatar
Bstomper Bstomper is offline
Man that's so cool. I wish I had more time to spend in the shop building.........or any time to spend in the shop for that matter. I haven't even had time to figure out how to use my last upgrade of pro.
Old 02-16-2016, 10:08 AM
90DROPTOP's Avatar
90DROPTOP 90DROPTOP is offline
just updated my software to SE with roll cage, sheet metal, and motorsports template. going thru the tutorials this stuff is amazing.
HTML code is On
