Old 09-20-2016, 10:32 PM
Bustawelds_one's Avatar
Bustawelds_one Bustawelds_one is offline
Finish sanding bumpers...getting pinholes. Need a remedy
I work at a local offroad fab company as a welder, We do production bumpers MIG welded and cut on a CNC plasma. All slag is sanded off and all corners to be welded are also sanded completely til nothing but fresh metal is exposed.
Problem is, after welding all outside corners and finish sanding we get pinholes. No matter how clean and sanded down the steel is, correct weld position and welder set up. We still get pinholes. We've had our air compressors and CNC plasma serviced recently so we werent getting contaminents from the cut but nothing is fixing the problem.
Entire bumper is plate, outside corner welds.
Does anyone have a remedy or why we get pinholes still?
We use 75/25 mix, 26 to 30 CFH. .1875 mild steel, VIKING .035 wire with cleaner on it to keep it clean before it enters the sleeve.
Old 09-20-2016, 11:27 PM
"26 to 30 CFH."
Too high? 100% total guess, only thing that jumped out at me.
Also, whats the "cleaner"?
Old 09-20-2016, 11:33 PM
That does seem kind of high on the flow rate. Sounds like impurities / cleaning issues to me.
Old 09-20-2016, 11:57 PM
"26 to 30 CFH."
Steel wool wrapped around the wire, right off the spool inside the machine.
We normally weld with one garage door open, or atleast partially but never enough to create a breeze.
Old 09-21-2016, 12:17 AM
Is this a full tube bumper?
Is it building pressure?
Old 09-21-2016, 12:20 AM
Forgot to add its all .1875 PLATE, all the welds are an outside corner weld.
Old 09-21-2016, 12:51 AM
Try welding with the door shut. I work at a pipeline facility for a little while and had my ass handed to me when the overhead door was open.
Old 09-21-2016, 08:28 AM
If your CFH is that high you could be drawing air into your weld. High flow can cause turbulence especially if you have a narrow opening. If the inside of the tip has build up that can cause turbulence as well. Does the CNC plasma have a water table? If so is there any additives in the coolant? The plasma cut edge itself may have impurities imbedded.
Old 09-21-2016, 12:14 PM
Can you see the weld puddle gassing? I would think you can.
Old 09-21-2016, 07:07 PM
This is what I was referring to. I have had my regulator set too high in the past and noticed pitting/holes in my welds as a result. 28CFM may just be too high
Welding near an open door or breezeway can also be a problem.
From your description of the "cleaner" it sounds like you're referring to a cleaner for the welding wire, but what about the base materials themselves? What are you using to clean the tubing before you weld? i.e. mineral spirits, isopropyl alcohol, degreaser, etc. That is what I was referring as a potential cause.
Old 09-21-2016, 11:27 PM
Clint, bumper is all plate.
"The plasma cut edge itself may have impurities imbedded. "
What Scootek said would be my next guess. Sanded or ground?
Old 09-22-2016, 09:30 AM
Whoops. Strike "tube' and replace with "plate" in my post above.
Old 09-22-2016, 01:35 PM
Beware of cross contaminating Metals with your sanding / abrasive discs. Have dedicated disks for each material so not to cross-contaminate materials before welding.
Old 09-23-2016, 10:49 PM
Sanded. I havnt touched a Grinding disc at work in months.
We only do steel. Well rarely other materials.
Old 09-23-2016, 11:53 PM
Pictures would be a very great help.
Just what type of equipment ??
Is there a reason your running your shielding gas flow so high ??
Like welding in a wind tunnel??
Is every one having these problems??***
This is the important question if it is everyone it comes down to gas wire or base metal problems
Is the shop run on a manifold system or each machine has it`s own cylinder ??
Hard to believe every machine in there is sucking air someplace .
So very many different possible causes one step at a time
Might be a heat soak problem outside corner getting to hot and taking to long to cool allowing the trapped gases to work out.
Are you starting at the corner and welding towards the center ??
This is why being up close and personal is so much easier
Is each welder setting up his own machine ??
Just what position are these bumpers welded in ??
Have you talked to your wire supplier and Gas Supplier ??
Has anyone watched this happens that knows just what they are looking at??
Old 09-24-2016, 10:22 PM
Old 09-24-2016, 10:45 PM
Just what type of equipment ?? Miller, 211 and 252 is whats used for bumpers
Is there a reason your running your shielding gas flow so high ?? Pretty sure thats the norm, and what the machine calls for.
Like welding in a wind tunnel?? closed shop most of the time, trust me if there was a breeze running through the shop all welding would cease.
Is every one having these problems??*** Yes
This is the important question if it is everyone it comes down to gas wire or base metal problems Swappped to C10 and NON copper wire today. Havnt had a chance to finish weld/sand a bumper yet.
Is the shop run on a manifold system or each machine has it`s own cylinder ?? Every machine is individual.
Are you starting at the corner and welding towards the center ?? Motstly running a C pattern for weld build up and a consistent weld.
Is each welder setting up his own machine ?? Yes
Just what position are these bumpers welded in ?? ?? please specify
Have you talked to your wire supplier and Gas Supplier ?? At the shop weekly giving ideas and trying to find solutions.
From what I am throwing together, its moisture from the humidty. Sounds unlikely but its fact backed.
