Old 05-19-2016, 10:25 AM
corbeau seat vendor?
Looking for:
Corbeau, Baja RS, Black/Grey cloth, Lumbars.
Best price thus far is a tic over $750 shipped
Old 05-20-2016, 01:03 AM
stock93's Avatar
stock93 stock93 is offline
I can probably drop ship them to you. PM me your zip code and I'll price them for you.
Old 05-23-2016, 12:47 PM
Clean your box...
Old 05-23-2016, 10:49 PM
stock93's Avatar
Cleaned out my messages. Sorry about that.
Old 07-05-2016, 03:43 PM
Note to y'all:
This deal was great!
Thanks G! Hope they were cold & tasty
Old 07-05-2016, 10:00 PM
stock93's Avatar
You're welcome. Glad your happy with the deal. Thanks for the
Old 07-12-2016, 04:54 PM
Always!
Always!
Always!
Check that your idea will work before you get it into paint.
Seats are great!!! ...but I can't raise them that far without cutting a hole in the roof.
Wish I would have checked that B4 I spent a day fabricating.
No, I didn't have the head room I thought I did
E <<-Idiot
Old 07-12-2016, 05:05 PM
Ah man that sucks. Time to cut something.
Old 07-12-2016, 06:34 PM
Fortunately, I have the raw stock.
Unfortunately, the other brackets were all made from drops these are all new stock.
Serves me right... I know better
In my defense I will note that hanging seats in someone else's ride I can actually see the skull to Roof/Cage relationship a thing I could not do for myself.
Half way done with the much shorter bracket... And yes I have some cheeze
Old 07-12-2016, 06:41 PM
On a side note, I have been thinking about Corbeau's retractable harnesses to replace the original, aging non-retractable and separate lap / shoulder harnesses in my Nova. They refer to them as 3 point harnesses due to 3 attachment points but they seem similar in function to 4 point harnesses in the way they support the shoulders and lap, while the retractor should make them easier to get in and out of. Any thoughts/opinions? What are your plans for belts? And what vehicle is this for?
Old 07-12-2016, 07:09 PM
I do not put permanent 4-point harnesses in anything that will be street driven.
Reason is if they are there you must be wearing them or you can be ticketed...
Removable 4 point gets the nod. 4-Pt is a PITA in the street, safer, but not convenient. Generally I try to find a OEM replacement part it is just less hassle.
This is for my DD Ranger, the OEM 3-PT belt is my choice.
Old 07-12-2016, 07:15 PM
Well the reason I like the Corbeau retractable harnesses is they are easy enough to get in and out of that I don't think there would ever be a problem with putting them on. An online friend that installed these took a video for me so I could see how they function - they look pretty easy/quick to put on and allow some range of motion for reaching things.
https://www.youtube.com/watch?v=m4hJwTuAsIo
However I also did a little reading up and came across this article which recommends against 4 point harnessed based on how the buckle ends up against vital organs if you submarine. They seem to think a factory 3-point belt would be safer.
http://www.ogracing.com/blog/2013/02...ing-harnesses/
Hope you post up some photos of the final install. I wish I had some comfortable seats that fit me properly!
Old 07-12-2016, 09:49 PM
I had the retractable Corbeaus in a Jeep and they worked good. It was street driven and offroad...then progressed to only offroad. In a DD car, the mechanism is not open to the elements that would cause it to jam up, but offroad they got sticky and failed on me so out they went in favor of fixed shoulders. Get the cam lock which lets you run the sub belt and the lap belts and click in the shoulders when needed.
The buckle will not be near vital organs if the belts are mounted properly. They should go around your hips and with the sub strap the laps wont ride up or you slide down.
Padded shoulders make all the difference in the world as far as comfort! i regulary take tumbles both slow and soft to hard and violent offroad and properly strapped in I dont feel anything afterwards. Before, with the shoulders loose, i felt like i was beat up from all the bouncing around, not so much anymore.
I know this is apples to oranges, but frontal/side crash is the same as my up and over, pirouettes.
Fast forward to 3:30
A little rockbouncing..
Comfy and properly fitted seats are a must or you'll hate driving your ride and/or wearing your belts. Get ya some good suspension seats
Old 07-12-2016, 11:20 PM
I did a fair amount of reading about seats a few years ago. I decided against suspension seats because you cannot get the belts to stay tight when the suspension is working. This could lead to spinal compression fractures. I think you could overcome that problem if you could have the seat suspended with the belts attached to the seats ie; the seats moves with you solidly strapped into the seat. Maybe seats are different now. The other decision I made was to go with a ratcheting lap belt as I couldn't get my belt tight enough without. This decision was made after a fairly mild rollover where I thought my belt was tight but in the roll I bounced around quite a bit. The belt I went with is made by Hooker Harness who seem to be well regarded in the airplane racing circles.
Old 07-13-2016, 12:44 PM
We did the same research
I chose the suspension seat because I am hoping that they let me get back to enjoying driving again.
Over the past couple years I have learned the definition (at-least in my case) of chronic pain.
I am generally ready to get out of the rig in about 30 miles or so... 4 the day
The small Ranger cab I am hoping the suspension seat will allow enough movement,
I can accept the risk, and these are better then the OEM seats ever were...
I just want to do some trail running without spending days afterwards wishing I had stayed home!
Old 07-13-2016, 12:50 PM
This is key. As long as you [and others] are aware of the risk.
Old 07-13-2016, 03:30 PM
They are hung...
Pix shot on a Tablet no accounting for the colors...
Old 07-13-2016, 03:52 PM
Damn nice work E! Looks better than factory.
Old 07-13-2016, 03:59 PM
Well I don't know if I would go that far but Ill accept if you say so.
The OE seats were really nice and they did get to over 280k-miles before replacement.
I plan on having them built and I'll use them in my mythical Willys Project that I am gathering parts for.
I would have liked the seats to move farther back but there isn't room side to side; gained maybe 3/4".
Old 07-14-2016, 09:41 AM
That's pretty sweet. I dig it. Looks like a good fit.
