Old 01-16-2015, 03:42 PM
AlxJ64's Avatar
AlxJ64 AlxJ64 is offline
Dum dum Mag-Brake question.. bending a Hat.
I have a nice 4' Baileigh mag-brake... but for some reason I can't for the life of me... see the forest for the trees... on how to bend a small shaped hat with it.
Its small, which may be the problem (thats what she said)...
The hat is 1" tall, with .5" wide leg flanges and a .75" wide center flange and I am using 16 gauge. Its a reproduction seat support flange for a WWII truck. Its structural and aesthetic so I'd like it to be correct.
Can I bend this on the mag brake? So far I end up with one leg that I can't get far enough into the bender because of the other leg hitting the brake leaf.... Advice... I really feel like a newb for asking this because Baileigh lists the "Stiffening Rib" in their "possible bends" portion of the manual but no real advice on methodology as they do for the hem or rolled stock bends.
Thanks in advance for your patience or mockery.
Old 01-17-2015, 01:41 AM
Ask Shane.
http://www.offroadfabnet.com/forums/...ighlight=brake
Old 01-17-2015, 01:58 PM
I'm not too sure on what your bending, a drawing would help. However, if I'm picturing this correctly, I think the order of bending might help. I would start with one outside flange and then go to one inside bend. Then the other outside flange and finally the last inside bend using a metal piece with the same inside dimension as the finished piece you want.
Richard
Old 01-17-2015, 05:00 PM
kkroger's Avatar
kkroger kkroger is offline
I believe he is referring to a Hat Section rail... Don't know the exact width or height but is should be simple to do using alternative fingers on the mag brake.
__
_| |_
