Old 08-02-2014, 10:44 PM
2Xtreme's Avatar
2Xtreme 2Xtreme is offline
Big box home improvement store wire...
I've noticed at the major auto parts stores you can only get wire up to 20' or so in length.
Walking through one of the big box home improvement stores today, I noticed 25', 50', 100' rolls of 'THHN' (??) stranded wire.
Is this suitable for 12v automotive use?
Thanks in advance!
2X
Old 08-03-2014, 04:04 PM
Brian1's Avatar
Brian1 Brian1 is offline
No for a few reasons. The outer coating is usually not oil and other automotive chemical resistant, it is not heat resistant and it is usually thinner which means it could chafe much easier and arc to the metal it is in contact with. The individual wire strands are also thicker than automotive type wire which means they will break quicker from vibrations and bends/movement
I buy 100' spools of automotive wire from Waytekwire, the pricing is usually much better than the shorter wires you can find at auto parts stores.
Brian
Old 08-03-2014, 06:42 PM
2Xtreme's Avatar
That's what I assumed.
I just hate having an extra splice, just to get the length I need.
And since most of my work is repairs (sigh), I'm not usually able to plan ahead and order in advance....
Old 08-03-2014, 06:58 PM
You need TXL at a minimum. SXL or GXL can also be used - they have thicker insulation. THHN is not rated for oil and heat.
You can buy black and red TXL by the roll. Cheapest source I found for different color or multi-packs of colored wiring was motorsportswiring.com
David Gilbert Motorsports Wiring 360-624-1955
I think Waytech may still be cheaper for longer lengths but they have minimums.
Old 08-04-2014, 02:26 AM
If you know your going to be doing electrical repairs why don`t you have the wire before you need it.
I most often buy in 250' or 500' rolls what ever I get the best price.
I am lucky we have a factory a few miles away that makes automotive wire.
Old 08-04-2014, 08:25 AM
Learned something here. I wired my trailer with THHN, no issues so far, but that's a little different than the typical "automotive" application. It's good to know what the right materials are to do a job, because the time and effort involved are the same either way, and they double when you have to do it over with the right stuff.
Old 08-04-2014, 02:25 PM
2Xtreme's Avatar
That's a good point. But the possible combinations of gages/ colors is pretty long.
What do you keep on hand?
Old 08-04-2014, 04:07 PM
I used THHN for my teardrop trailer wiring. There is no engine heat or oil nearby, so I wasn't too concerned. The only additional concern is vibration/rubbing, but the insulation on THHN seemed sufficient with looming. I think the bigger concern there is on connectors/terminals. I used crimp plus solder on those; wish I had a wire welding machine.
Old 08-04-2014, 04:52 PM
I used heat shrink + glue crimp connectors from Del City on my trailer. Plus lots of grommets, clamps every 12" and tape in between the clamps so the wiring couldn't move around much. The only issue I've had is the loom I got from Summit Racing to bundle the wires together where they go into the trailer connector is not resistant to UV light. It has started to disappear in the two years since I rewired the trailer. Should've used heat shrink...
Old 08-04-2014, 05:41 PM
Just to add info to the thread. TXL, SXL and GXl use cross-linked polyethylene insulation. THHN uses PVC + nylon. They both tend to use bare stranded copper conductor, but THHN can technically also be aluminum.
Temperature rating and thickness/weight are the main differences:
TXL -40 to 125C, 0.078in dia (18awg)
THHN -105 to 80C, 0.090in dia (18awg)
Old 08-05-2014, 08:14 AM
I don't think you will find much THHN wire that's aluminum in the sizes you would want for a car. Aluminum wiring in small gauges is against code in most places so it's not made anymore. Big stuff still can be aluminum (think main feed into a house), and is in a lot of cases because of the outrageous cost of copper these days.
Old 10-20-2014, 12:37 PM
RogueFab's Avatar
RogueFab RogueFab is offline
I usually hit Ebay for 12v wire. Just make sure you buy from a seller that knows what they are doing. Lots of jerks selling speaker wire for auto use. Obviously a no-no.
