Old 02-14-2014, 04:17 AM
Walterronny's Avatar
Walterronny Walterronny is offline
Testing Bend Tech and Jd32!
HI there! finally i got today some hours to work with bend tech and Jd32 and test it as first time 50mm die set, i used already 30mm die set and works great, i can't say the same for 50mm, i will test the other40mm die set soon.
i tried to calibrate Bend tech but it looks like i did something wrong so didnt match what i designed with the tube i bended, finally i used default Oem list and worked really great, good job Bend tech guys!.
On the other hand, i bend 50mm x 2.5 tube ST35 Steel, and i didnt like how bends looks like, i dont know if im doing something wrong, it's supposed im using a tube that will works good since in US use 1.75 X 0.95 thickness and bends looks really great..i dont know maybe im doing something wrong? here some pictures, let me know what do you think!
it really doesnt show enough the "damage" of the bend
ST35 50.00mmX 2.500mm CDS Steel..
i assume using 3mm thickness will works better but it's supposed that with 2.5mm bends should looks better? im doing something wrong? i of course use grease for tube and dies.
Old 02-14-2014, 08:52 AM
2.5mm wall will look worse than a 3.0mm wall. As the material is thinner it will crinkle more. And the material type will make a difference. You should contact JD2 and see if they can help you.
Old 02-14-2014, 11:18 AM
Scrambled's Avatar
Are you using the correct die? I bend a lot of 1, 1 1/4, and 1 1/2 sched 40 pipe. There is a little distortion where the tube flattens out.
I have a jd2 mod 32 and use BT also.
Old 02-14-2014, 08:05 PM
2.5 is thicker than .095inch (2.4mm)..and ive seen good bends with .095 thickness, steel i use is CDS.
I use Metric die sets since im from Spain, 50mm die set.. i will contact to JD2 for this
