Old 09-10-2014, 02:03 PM
BAILEIGH INC's Avatar
Geat video:
https://www.youtube.com/watch?v=RnqFnShSJvQ
[/quote]
Shane Henderson
Baileigh Industrial Inc.
shenderson@baileighindustrial.com
www.baileighindustrial.com
920-482-3220
Quality Metal Fabrication Equipment
Old 09-11-2014, 12:25 AM
quadboy's Avatar
quadboy quadboy is offline
What the thickest metal you can or have bent ?
Old 09-15-2014, 12:36 PM
AlxJ64's Avatar
AlxJ64 AlxJ64 is offline
Saving my pennies and trying to sell some parts to pick one of these up. Would I be best to order direct through you guys Shane? Or go through a Vendor? Who's that special someone to speak to about the shop banner?
Btw, this is PowerwagonBuilder from Instagram, you shared my "Dirty Hands Anvil" last week and for that I thank you! I ended up selling 3 of them via IG messages and Paypal... money in your pocket for a new Baileigh Tool!
Old 09-15-2014, 01:14 PM
Glad to help the cause brother......
Call me direct for the hookup 920-482-3220
Shane Henderson
920-482-3220
Old 09-15-2014, 06:20 PM
Jhnyquest's Avatar
Jhnyquest Jhnyquest is offline
How thick of material can you bend with this?
Old 09-15-2014, 06:41 PM
These specs say 16 gauge for steel 20 gauge for stainless:
http://metal.baileighindustrial.com/...brake-bb-4816m
Old 09-25-2014, 04:44 PM
Insane.....
Shane Henderson
920-482-3220
Old 09-25-2014, 05:00 PM
Jhnyquest's Avatar
Impressive
Old 09-29-2014, 09:56 AM
AlxJ64's Avatar
Mine showed up while I was out of town on a work trip. Getting caught up with day to day stuff, expect some future updates. I'm excited for this thing. Thanks again Shane and I'll have plenty of pics to share once I get back in the swing of things. I haven't even had time to finish unpacking it yet.
Old 01-17-2015, 09:11 AM
AlxJ64's Avatar
So far I love the versatility of this machine for making reproduction or custom parts for my WWII truck rest-mod... but for some reason I can't for the life of me... see the forest for the trees... on how to bend a small shaped hat with it.
The part is small, which may be the problem (thats what she said)...
The hat is 1" tall, with .5" wide leg flanges and a .75" wide center flange and I am using 16 gauge. Its a reproduction seat support flange for a WWII truck. Its structural and aesthetic so I'd like it to be correct.
Can I bend this on the mag brake? So far I end up with one leg that I can't get far enough into the bender because of the other leg hitting the brake leaf.... Advice... I really feel like a newb for asking this because Baileigh lists the "Stiffening Rib" in their "possible bends" portion of the manual but no real advice on methodology as they do for the hem or rolled stock bends.
Thanks in advance for your patience or mockery.
In all serious though, any advice? Thanks!
Old 01-19-2015, 08:14 AM
I can help....send me a pic shenderson@baileigh.com
Shane Henderson
920-482-3220
Old 01-19-2015, 10:37 AM
It is a 1" tall "U" bracket with .75 across the middle. Add .5 flanges on each end that flare out at 90 degrees. Basically looks like a cross section of a top hat (hence the term "hat section").
Old 01-19-2015, 10:45 AM
It looks like it might be a little too small for the mag brake. You need around an inch lip or so (depending on the material tensile strength)
Shane Henderson
920-482-3220
Old 01-19-2015, 11:55 AM
How could it be done if the values were an inch or 2?
Old 01-19-2015, 12:03 PM
I use a light duty 10 1/2' brake bending aluminum cladding for windows and doors. The manufacterer spec for flanges is 3/4". I regularly get 1/2" by clamping the flange side and bending on the long side of the alum. sheet. On shorter lengths I can get to 1/4" flange. Perhaps that technique could be used here?
Edit; it just clicked why he's having problems. I take it that from the edge of the clamp to the outside of the bending arm is longer than the measurement B minus T-1 [material thickness]?
Old 01-19-2015, 01:17 PM
Yea, it sounds like the reverse bending is forcing the material into the table or into the swing arms. Can I guy unbolt the extra rail so the material can lip over the end?
Old 01-19-2015, 01:24 PM
Yes it comes off, we are trying to make the part here and are struggling
Shane Henderson
920-482-3220
Old 01-19-2015, 02:32 PM
Make all the bends in your brake to about 45 in the correct direction.
Take a piece of hard wood or Aluminum (stuffer) that is slightly smaller then the inside of the hat when finished.
Using an old fashioned vice with the inside of the top of the hat above the vice jaws (or the other way round depending on the vice) and simply squeeze the part into the "U" shape.
Flip the part over in the vice and position the part so that the vice jaws are right on the bend line and using an aluminum bar about 1/2" thick and gently work the bend to the 90 that you want for both flanges.
Tune up the bends as necessary and sand to remove any tooling marks.
Sorry can't help with the magpress
You can not depend on your eyes when your imagination is out of focus. MT
Old 05-13-2015, 07:31 PM
kazlx's Avatar
kazlx kazlx is offline
They are awesome. This project is nothing fancy, but way better than a finger brake.
Old 08-21-2015, 08:40 AM
Shane Henderson
920-482-3220
