Old 11-25-2013, 09:34 PM
plug ugly's Avatar
plug ugly plug ugly is offline
Scugly, build sumary
Been on the site for a while now, and recently got the rig to where I can run on the trails. Its been a few years, and its nice to be back in the seat. Still lots to finish up, but thanks for the advice on the build.
Maiden trip went really well. This thing is super stable, suspension works well with no quirks found yet. I need to get used to the lower belly height compared to the last rig, but Im really pleased.
Started with a rust bucket
Started with beefing the frame mid section and stretched the rear 8"
Old 11-25-2013, 09:36 PM
plug ugly's Avatar
Stuck a ford 351, ZF, klune and 205 in there with some block hugger headers
motor is offset 1 7/8
Old 11-25-2013, 09:38 PM
plug ugly's Avatar
4 linked the rear with early bronco coils
Old 11-25-2013, 09:40 PM
plug ugly's Avatar
3 linked the front 60
upper link mount and gusset to the top of the housing
1.75 188 wall truss, slightly angled down for clearance
finger worth of clearance at ride height
new middle body mount
rear mounts.
Old 11-25-2013, 09:42 PM
plug ugly's Avatar
Redid nearly the whole interior
New rear fire wall made of 16g. This will sit right behind the back seat.
Got a little time in the garage. here are some in progress pics
Got the new bulkhead mocked in. Still need to finish welding
Weld flange is on the back side
the rear deck lid fits over the new bulkhead
Cut 22" out of the rear inner fenders. Gives a lot more foot room for my kids and should make for a better B pillar cage mount
Also gives a lot room for the front eat to move back some
Old 11-25-2013, 09:44 PM
plug ugly's Avatar
made some mini- boatsides
cut outs in floor and A pillar cage mount if you look close
32.75 to top of rocker
modified the firewall and tunnel cover a lot
Old 11-25-2013, 09:47 PM
plug ugly's Avatar
raised the front frame horns for a lower lift hieght
gussets for the cross members
front frame plates
front 3 link brackets
Old 11-25-2013, 09:50 PM
plug ugly's Avatar
go the tub lined, had a custom fuel cell made to hold about 28 gallons. Uses an explorer intank high pressure pump. Modified the bronco lines to work
Had to modify the ps pump mount to fit with the forward swing ford saginaw box
Old 11-25-2013, 09:53 PM
plug ugly's Avatar
used a combination of different ford serp brackets
some flex testing shots
Radiators mounted
About .5" clearance under the hood
Old 11-25-2013, 09:54 PM
plug ugly's Avatar
I took a few steps back and redid how the fuel tank will sit. I raised the tank 2" because the dif was going to contact the tank skid, and limit my uptravel to 6" or so. By raising it 2", I get full stuff of the coils. The coil stuffs to about 8.4" and I will now have 8.5" stuff at the coil buckets
This gives me 1" clearance of the dif at the skid
21"clearance at the tire to ninja bars , with the 42" tire it should be perfect
and 1" clearance between the upper links and bottom of the tub
so it should be about perfect, which is partly luck and partly planned
The only issue is the pinion will be slightly pointed up at full stuff. Hopefully it wont be an issue
full bump, full lock to drivers side. Clearance is tight, but it clears
Ram mount
Ram hangs a little lower than I wold like, but Ill have to live with it and make some protection for it.
Old 11-25-2013, 09:56 PM
plug ugly's Avatar
Also got the exhaust done. Had the local shop do it, I just didnt have time or patience.
dash is done, but no pics, some other stuff got done, but no pics as I was trying to get ready for a trip and just get it on the road.
Old 11-25-2013, 09:58 PM
plug ugly's Avatar
Still need to finish the bumpers, hood (8" pinch in the front) and finish the rear skins, but i got it out on the trail for an annual run
walked right up soup bowl
old sluice kicked my ass. Have to get used to the low belly height
winch hill 1
boat side was digging in, damn low belly height I am not used to yet, so I went a little farther up the left side. Rig felt totally stable, but reports from behind were it looked way over. Didnt feel a tire lift at all.
Old 11-25-2013, 09:59 PM
plug ugly's Avatar
And that catches you all up. comments, good bad and ugly?
Thanks again for the help over the last few years.
Old 11-26-2013, 03:58 PM
Good in a ugly Badassed sort of way.
Old 11-26-2013, 10:51 PM
crippler's Avatar
crippler crippler is offline
Fugly
Well done !!! That is one sick looking corn binder !!!
Old 11-27-2013, 01:40 AM
johny5's Avatar
johny5 johny5 is offline
Nicely done . Thanks for sharing
