still catching up
I decided that the engine bay needed a different finish to break things up. Welcome carbon fiber.
Picked up some supplies from Composite Envisions to try my hands at CF wrapping, as long term I wanted to do the front splitter anyway.
Grabbed a few yards, of this, plus the necessary resin and black pigment to tint the base layer.
First layer of tinted resin on, fabric cut to size.
This was definitely the worst part. The resin is very thin and didnt stay on the sides well, so the fabric didnt stick as well as I liked and I ended up attempting to tape it to the backside while things set up. one spot was also too thick and bled through. For future projects Ill need to figure out how to deal with this. Id think a little thicker resin would help.
Laid / taped in place.
Bleed through.
First coat of clear top resin.
A few more coats later.
After that I blocked it flat and ended up with a few voids, likely from the first layer not sticking well to the sides.
I didnt want to scrap the piece so I decided to patch them as they were on the side anyway.
Mixed up a little filler and tinted it with the resin tint black.
And then a final coat of resin.
And then wetsanded and buffed it out.
The edges still had some spots you could see the base under, from sanding through etc, so I back taped the top and dusted some trim black paint on the edges. It did the trick even though its still not perfect, Im pretty happy for a first attempt.
Installed
