Old 03-13-2017, 10:50 PM
Rastus's Avatar
Rastus Rastus is offline
Welding Critique
How do these look? I keep making small adjustments to the settings, but I never really get the sizzle sound. aka bacon frying.
Welder is a Eastwood Mig 175.
thanks..
Fame is vapor, popularity an accident, riches take wings. Only one thing endures and that is Character.
Rockkrawler.org
Old 03-14-2017, 11:23 AM
...sitting here, drinking a cup-a-Joe, for the most part things look acceptable,
but it also looks like there is a slight bit of under-cutting which could be
heat or wire or hand technique... I'd try bringing the wire speed up a little and
see if that gets you into the bacon.
Oh, never mind...
Old 03-19-2017, 01:45 AM
310kick's Avatar
310kick 310kick is offline
I would start by removing the rust and making sure the metal is clean. You will see a difference for sure. Are you dragging the gun in a straight line? If so practice on making a C pattern remembering to stay on the front edge of the puddle.
Old 03-19-2017, 07:33 PM
If you leave the voltage alone slowing turn up the wire speed till it bounces off the puddle.
then slowly back off to it quits
Those welds are just a little on the to hot side either voltage to high or wire speed to slow
I really never hear the frying bacon unless it is someone else
I always wear ear plugs one spark hitting my ear lobe was enough
Then just what size wire are you running .023 ??
